Corsair H70 noise
21 Jan 2011
So Initially I'd assumed that the noise was coming from my Graphics card, but on closer scrutiny I discovered it was actually the H70 CPU cooler I put in my system.
Its making kind of a purring noise, like a faint rattle.
Has anyone else had this? If so, how do i eliminate it! :D
Maybe you need to de-airate it (i.e remove any air bubbles stuck in the pump.)
Although, with it being a plug and play cooler, it should already be done.
You could try hitting it a few times with a spanner first...
I got it sorted out.
Swapped out one of the fans for the original Lian Li one that was in the case, which is actually quieter still :P
So yeah, simple solution :D
All is good.
Thanks for the input, part from the hitting it with a spanner! lol
