After thinking about getting the Thermaltake 850i prowater ( It looked good with the UV Tubes Etc ) i've now thought about getting the H70 as it seems much better even if it does look abit boring
( Both are around the same price anyway)
I currently have an Akasa air cooler with a broken pin which means it cannot be fastened down securely so either way i need a new cooler.
Am i right in thinking the H70 doesn't need refilled or cleaned / changed?
And do you think it would do the job for me? ( OC @ 3.4ghz ).
( Both are around the same price anyway)I currently have an Akasa air cooler with a broken pin which means it cannot be fastened down securely so either way i need a new cooler.
