Corsair H70
24 Nov 2009
Edinburgh, Scotland
Hi,
I am looking to buy an H70. However, I noticed that it comes with two 120mm fans. This is a problem as my case uses 140mm fans. Is there an obvious way around this?
Cheers
Your Case Manufacturer & Type please?
Any case which can mount 140mm fans should also be able to mount 120mm fans using the extra set of screw holes provided.
