Corsair H80 Push/Pull
31 Oct 2010
hey guys i have just purchased a h80, and want to know if anyone has the best config for push and pull on a 650d.
Thanks in advanced ohh and one more thing if i pull air from outside the case doesnt it mean it will collect dust way faster cheers.:D
I'm sure I saw a port (on here? not sure) of some temps pulling into a case and pulling out of a case, the corsair recommended way came out better by 3-5c which is to have the fans pulling cool air from outside of the case.
I haven't noticed any dust build up at all from my H80.
Push/Pull will force more air through the radiator giving better cooling of the liquid in the pipes/tubes keeping your cpu cooler, but it will attract more dust.
To keep the case cooler, you should have the radiator on the rear fan slot pushing air IN (cooler air) and have the top fan(s) pulling air out as usual.
Dust be a ***** and everyone hates it. Only just cleaned my case out for the first time since January and it was so dusty I kept on sneezing lol.
thanks for the input lads, just dont want to have to gas my pc every week to get rid of dust to save 3c mite just keep to pull/push unless there is any other reasons cheers guys
