Hi,
Is it worth the upgrade from a H80iGT to a H110GT? ... Have had to remove my overclock as my temps were hitting high 80 degrees under full load.
My computer is in the corner of my room with the 120mm fan cutout approx 6 inches from the wall. (only way I can have my case without moving my whole room around)
I do a fair amount of video encoding so PC sits at 100% for some time.
thanks.
thanks.
