Corsair HX 620W - Whic sockets are which rails?
10 May 2004
Derby, UK
Just received my nice new Corsair HX 620W power supply... its one sexy beast (well for a power supply anyways) :D
I've installed it on my system and everything is working ok - but as I was installing it I was wondering something...
The modular sockets that the cables connect into - are they split between the 3 x 12v rails? I just thought that if they were specific for each 12v rail (say 2 sockets for one rail, 2 sockets for another rail and 2 pci-e sockets on the final rail) it may be worth knowing which is which so that I can plug them in and spread the load evenly between the 3 rails?
Anyone any ideas?
Thanks for the quick reply....
So if I understand you your saying even though there are 3 x 12v rails (each at 18a each) its actually 54a total and as its distributed between the 3 rails one rail could be using says 24a while another uses 3a....
As long as the total isnt over 54a?
Thats cool if thats the case!! :D
