- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair HX 750W ATX Modular SLI Compliant Power Supply (CMPSU-750HXUK)
Corsair Professional Series power supplies set a new standard by which all premium PSUs must be judged. Designed and engineered using cutting-edge technology, each Corsair Professional Series power supply is built to the highest quality standards, and delivers the features and performance that technology enthusiasts demand.
- Enhanced modular flexible cables enable easier cable routing and increased airflow in the system
- Guaranteed to deliver rated specifications at 50ºC.
- Supports the ATX12V v2.3 and EPS12V 2.91 standards and is backwards compatible with ATX12V 2.01 systems
- Double forward switching circuitry design offers high efficiency, up to 90% under typical load range
- Active Power Factor Correction with PF value up to 0.99 provides clean and reliable power to your system
- Ultra quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying the RPM in response to temperature.
- Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety for your critical system components
- 105ºC rated industrial grade capacitors provide uncompromised performance and reliability, delivering 4 times the lifespan of conventional 85ºC rated capacitors
- Dimension: 150mm(W) x 86mm(H) x 180mm(L)
- MTBF: 100,000 Hours
- 7-Year Warranty
BUY NOW for only £114.99 inc VAT.
- 7-Year Warranty
