Corsair Hx650
13 Jan 2010
A box in the Astral Plane
Will using cables for my hx650 that didn't come with the PSU void the warranty?
If so, then what about just braiding the cables? Will that void the warranty?
If you mean by braiding them, do you mean just shoving them through some ready made cable braiding? I shouldn't think so, I mean if you have any problems then you can always remove it.
I'm not sure about the using non-Corsair cables. Tbh I'd just do it, and deny everything if they cause your PSU to asplode :)
