** CORSAIR HXi DIGITAL FULL MODULAR POWER SUPPLIES NOW IN STOCK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Corsair's latest and well priced digital HXi range is now in stock at OcUK. :)
Corsair HX750i Full Modular Digital Power Supply (CP-9020072-UK) @ £116.99 inc VAT
HXi Series power supplies give you extremely tight voltage control, virtually silent operation, and a fully modular cable set. With all Japanese 105°C capacitors, they’re a great choice for high performance PCs where reliability is essential. 80 PLUS Platinum efficiency reduces operating cost and excess heat, and together with Zero RPM Fan Mode technology, gives you virtually silent operation.
With Corsair Link Digital support, you can monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular, low profile cable set makes builds and upgrades easy, with clean, great-looking results.
80 PLUS Platinum efficiency and Zero RPM Fan Mode mean that at low to medium loads, the fan doesn’t spin at all. And when you do push the HXi hard, the thermally controlled fan spins only as fast as it needs to.
But that’s not all. It’s quieter than most PSUs when the fan’s not spinning, too. The HXi is built with capacitors and other internal components specially selected to reduce coil whine and other electronic noise.
Connect the included cable to a motherboard USB header and download the free Corsair Link Dashboard application for Windows and you can monitor performance and efficiency, toggle single rail or multi rail mode, and control fan speed directly from your desktop.
The fully modular, low-profile cable set allows for quick and easy installation and great-looking builds. The fan self-test switch lets you quickly confirm operation before you even attach cables to your motherboard.
Features:-
- Corsair Link™ Integration for monitoring performance and adjustment of fan speed and multi-rail/single rail mode.
- 80 PLUS® Platinum efficiency, delivering 92% energy efficiency at real world load conditions.
- ZeroRPM mode for fanless operation at low loads and outstanding noise reduction.
- 140mm thermally controlled fluid dynamic bearing fan spins up as needed.
- Fully Modular low profile cables for easy installation, less clutter, and helps maximize airflow through your computer’s chassis.
- Engineered to meet maximum power output at a server-grade 50C temperature rating.
- Fan self-test switch to determine fan functionality even before installation.
- Over-voltage protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, UL / CUL, CSA, C-Tick/RCM, TUV, CB, CU, KC Mark, RoHS, WEEE, RoHS (China), REACH.
Specification:-
- 80 Plus Platinum
- Power: 750 Watts
- Fanless mode: Yes
- Fan bearing technology: Fluid Dynamic Bearing
- Fan size (mm): 140mm
- C-Link Digital: Yes
- Continuous output rated temperature (°C): 50°C
- ATX Connector: 150mm x 86mm x 180mm
- Modular: Yes
- Sleeved cables: Low-Profile, All Black
- ATX Connector: 1
- EPS Connector: 2
- Floppy Connector: 2
- Four Pin Peripheral Connector: 8
- PCI Connector: 6
- SATA Connector: 12
Only £116.99 inc VAT.
ORDER NOW
Corsair HX850i Full Modular Digital Power Supply (CP-9020073-UK) @ £131.99 inc VAT
Features:-
Specification:-
- 80 Plus Platinum
- Power: 850 Watts
- Fanless mode: Yes
- Modular: Yes
- ATX Connector: 1
- EPS Connector: 2
- Four Pin Peripheral Connector: 12
- PCI Connector: 6
Only £131.99 inc VAT.
ORDER NOW
Corsair HX1000i Full Modular Digital Power Supply (CP-9020074-UK) @ £155.99 inc VAT
Features:-
Specification:-
- 80 Plus Platinum
- Power: 1000 Watts
- Fanless mode: Yes
- Modular: Yes
- ATX Connector: 1
- EPS Connector: 2
- PCI Connector: 8
Only £155.99 inc VAT.
ORDER NOW
Are these lower profile than my AX860i ?
In the 17 months I have had my PSU it has been smooth computing no odd sounds and 90% of the time the PSU is silent and even when the fan does kick in you don't really here it :-)
I don't really understand this immediate dismissal. By all accounts CWT are capable of making very good PSUs, very bad PSUs and everything in between to meet various price points... just like any other PSU manufacturer. The only reason to dismiss these is the price, which is way too high.
That's the point isn't it though? Buyers are being ripped off by being given an inferior PSU for the price considering the HX no longer has Seasonic internals which command such a price.
It's a brand new, completely redesigned product though with Corsair Link, 7 year warranty and Platinum rating. It was never going to debut at a price to match PSUs that don't have those things. And by all accounts so far it isn't inferior at all...
Would anyone pick one of these over a superflower psu? Also how good is the link software, starting to look at what psu to get for a new build.
