I have just finished installing the above and I have run a quick Prime95 test using Small FFTs'
Load temperatures are hitting over 60'c on all cores.
The system spec is as follows:
i2500k
MSI P67 GD53
I have applied Arctic Silver Céramique 2 using the thin line on the CPU method.
Nothing is overclocked, everything is running at stock.
The ambient temperature on the top of the case at the minute is 21'c
Should I just remount the heatsink?
i2500k
MSI P67 GD53
