Corsair Hydro H80 High Performance Cooler - IN STOCK NOW!!!!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
The new Corsair H80 has arrived at OcUK. With a new dual thick radiator and dual fans this CPU cooling system will have your processor frosty cool in no time at all.
Corsair Hydro H80 High Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) @ £84.98 inc VAT
Corsair Hydro Series liquid CPU coolers provide a compact, easy-to-install, and maintenance free alternative to bulky, noisy air coolers, efficiently cooling and protecting your high-performance Intel® or AMD® CPU. The H80 features a double-thick radiator to maximize the surface area available for heat dissipation and dual performance matched fans. It also includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs.
The Corsair Hydro Series H80 high-performance CPU cooler fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*.
* Requires the Corsair Link Commander, sold separately
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
Double-up for excellent cooling
Featuring a double-thick radiator to maximize the surface area available for heat dissipation, and dual, performance matched fans, the H80 delivers cooling performance that lets your CPU keep its cool, even when pushed to the limit. And with all this cooling performance, the compact design still fits virtually any case with a 120mm fan mount.
- Corsair Link™ Digital compatibility means that you can be in complete control of your cooling.
- Push-button fan control so you can select the fan speed and cooling performance that best suits your needs.
- Double-thick 120mm radiator for increased surface area and cooling potential.
- Two all-new 120mm fans optimize static pressure and airflow for amazing performance.
- FEP tubing provides extraordinarily low coolant evaporation levels.
- A new improved micro-channel cold-plate design more efficiently transfers heat.
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 38mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Up to 2600 RPM
- Air Flow: 46 - 92 CFM
- Fan Noise: 22 -3 9bDA
Only £84.98 inc VAT.
ORDER NOW
Are there any benchmarks yet?
How much better does it perform over one of the other hydro series coolers?
It is slightly better than a H70, but has added features which are unlocked with the new Corsair Software - for example, the ability to adjust the pump speeds/fan speeds depending on the temperature of the CPU.
Don't like the idea is this one: Fan Speed: Up to 2600 RPM (probably too loud)
Be the first to get a review up!! get testing.
Read the whole thread, I think I'll be sticking to a Thermalright Silver Arrow, the latest H80 cooler does not really break any new ground.
CorsairGeorge said:
The differences between H70 and H80 are:
  1. The H80 has a slightly thinner radiator. This makes it perform better with lower speed fans. The H70 radiator was so thick that low speed fans made it perform WORSE than H50 with the same fans. We thinned the radiator slightly (new radiator core is 38mm thick) and tweaked it a bit, so we had better performance all around, including low RPM fans.
  2. The H80 fans are specially designed for static pressure. The blade design is identical to our H60 fan, but while the H60 fan maxes out at 1700 RPM, the H80 fans are capable of 900-2600 RPM. The 7.7mmH2O number is at full RPM on a single fan.
Some other comments:
The thin, corrugated tubing is not the bottleneck for performance in our system when it comes to flow rate.
Apache fans are good, but are typically louder than fans of similar RPM with similar specs. The "S" shaped blade might be the cause of this, I don't know, I haven't done a blade pitch/design comparison. All I know is in our internal dBA testing, they scored fairly poorly from a noise level perspective.
The H80/H100 performance gap is small in out-of-box settings, but the H100 has much more headroom due to the capability of adding 2 more fans for a push/pull scenario.
The "Low Noise", "Balanced", and "High Performance" settings are not strict fan RPMs, but performance curves that let the fans spin up based on internal coolant temp. Their settings are as follows:
Low Noise - 900 RPM to 1300 RPM
Balanced - 1300 RPM to 2000 RPM
High Perf - 1600 RPM to 2600 RPM
The "Balanced" mode outperforms H70 by about 3C, consistently, on our test-bed with an ambient temp of 25C.
Source
I was thinking about this to replace my NH-D14. As great a cooler it is, it bloody ugly. I think I'll wait for the H100 and put 4 Akasa Vipers on it.
Bulldog you really do have tunnel vision!
I have not tested a H100 yet, but I am not passing judgement yet...... neither should you. Have you used one? No......
No, I haven't try H100 as they are not available out yet. But, I am sure you can prove me wrong when you get hold of it and tested it. :)
I am not out to prove you're wrong, you maybe correct. I just wish people would not pass judgement with no facts.
This has been available for a afew days now hasn't anyone bought any
interested to see what the results are
could be a preview to how well the H100 performs
tried search the net and loads of shops have this is stock but i cant find a single user review or unboxing or anything
If what he says is true then why have I never encountered this poor performance on the H70? but saying that I don't have a H50 to compare. I have good temperatures with fans at low speed as intake, about 38c gaming or prime. I don't have them cranked up to 163CFM because I don't want noise if there doesn't have to be.
Even before with two 1500rpm fans at 64cfm per fan throttled down to about high 6xx to early 7xxrpm exhausting, it would idle at 32 - 34c for web browsing.
just installed my H80 and less than 2 hours later Asus AI Suite has reported the fans aint spinning and the cpu hit 85°C....so i tried to shut the pc down, but i guess it overheated before it could fully shutdown.
When i took the side off the case, i could see the fans weren't spining and light on the cooler wasn't on, then the fans seemed to kick into life intermittently as if there was a loose power connection or something. I've checked all the connections and they seem fine. Everyting is plugged in too, 2 x fans into cooler, 3-pin from cooler into cpu fan on mobo, 2 pin power molex is connected too.
Any ideas please.
Its cooling my i7-2600k (@4.5GHz) on an Asus P8P67 Pro board. PSS is Corsair HX850w.
Daren't leave it alone now, will have to shut it down overnight.
