- 6 Nov 2021
- Scotland
Hi all
I recently purchased a Corsair Hydro Series iCUE H100i ELITE Liquid CPU Cooler - 240mm from overclockers and while i like it there's a couple of things that annoy me.
1. Even on quiet mode the pump makes a bit of a noise, not super loud or anything and I'm probably quite sensitive to it but still.
2. The RGB fans get very loud when stressed. They are connected via the corsair hub at the back with i believe is a 4 pin connector plus an rgb connector.
Would it be possible to replace the fans for a quieter model?
I'm not particularly bother about RGB and i was thinking about the Bequiet fans but then noticed they are predominantly 3 pin
Anyone any thoughts on this or recommendations?
Thanks
Thanks
