Corsair iCUE 465x radiator question
2 Jan 2016
Yorkshire
Hello all,
Currently shopping around for a new case and struggling to find something that will fit a 240mm radiator on top WITH clearance for RAM, plenty claim it but reviews on these suggest otherwise.
What I am wanting to know is the above case mentions 280/360 on the front... Is it possible to put a 240mm front aswell do you reckon or won't the hole placement be right?
Anyhow, any other suggestions for a case around the £70-80 would be welcome aswell but would need to support my AIO either front or back.
Thanks!
The lian li mesh has offset radiator mounting so may not interfere with the memory as it had an offset design ., there's an rgb version as well.
You can always mount your aio at the front of most cases.
https://www.overclockers.co.uk/lian...MI5KnMw5ey9QIVCLrtCh2cVQSgEAQYAiABEgLkpPD_BwE
https://www.techpowerup.com/review/lian-li-lancool-ii-mesh-performance-atx-chassis/4.html
Thanks will check those out, had assumed front stating 280/360 limited me to just those.
Will do! Last question then I shall leave you be.... Thoughts on the Lancool 215?
Nice case top rad clearance is 55mm which should be fine so check you aio spec.
Your Rad will be either 27mm or 30mm and fan 25mm.
Remember if you cant fit your aio top then you will have to front mount and those 200mm fans will be useless.
Rad is 30mm and Fan is 26mm so I am 1mm out!
@mickyflinn
