Hi
I've had a Corsair K70 for a few years now, and its been great up until now. Out of nowhere my windows started flickering, going full screen, print screen utility popping up and everything.
I eventually realised it was the keyboard which appears to be nonstop sending inputs to the PC, I've checked that no keys are stuck down and even removed several keys to check the switch isn't down. I can see that the scroll lock light is flickering non-stop. Tried flipping the keyboard tapping it, unplugging/reconnecting it etc, but I've had no luck resolving the issue myself. I even tried connecting it to my work laptop but got the same issue on that.
Does anyone have any suggestions on fixing this issue? Or is it a case of trying to get a replacement (if so would it be OCUK or Corsair I contact)?
I'm not entirely certain if they keyboard would still be covered as it was back in 2014 when I purchased it. Basically just need to try and sort it quickly for the weekends gaming hehe, I've resorted to using an old Logitech G510 which doesn't feel good after been so used to the K70.
Thanks in advance
Thanks in advance
