So I'm about to pull the trigger on a Corsair K70 /w brown MX switches.
But well, they're not cheap ! I have heard a couple of rumors out there that sometimes the LED's burn out ? and that you're kind of outta luck if it happens, because Corsair want you to return the KB back to them, rather than send you out a replacement then and there.
I guess I'd like to know if this is a geniune problem or just happened on a small few, but the small few are making a lot of noise about it.
Perhaps it was the 1st editions? Has anyone here experienced LED's going out on their K70's ?
