Corsair K95 keyboard Bundle
20 Oct 2012
west sussex
Have the keyboard but not the mouse. Keyboard itself does everything you need plus some. Looks neat with the RGB, all the function keys, the Macro keys are powerful to use and easy to set up and nice media control keys, in particular volume adjust. Hate using boards without this now.
The profile switch button also works well as each profile can have its own lighting and set of Macro's so if you play multiple games or say profile 1 is for working with excel etc its nice to do. Lighting works well and have as many options as you desire.
That is a pretty nice for both those parts. At most places you can just about get the keyboard for that price.
hi thanks yes looking at the price seems liek the mouse might be naff as the price is almost the keyboard alone price.
I have both and, for that price, it's a steal (almost :))
Took me ages to get used to them as my KB has the speed switches so very sensitive and the mouse is a lot larger than I'm used to. So might take you a while to get acclimatised
Overall, I recommend them both.
The keyboard is really nice to use. You just have to get used too the speed switches.
The bundled version only seems to come with the brown switches which is a shame as I wanted to try out the speeds.
