Corsair keyboard
Man of Honour
20 Sep 2006
I'm looking for a new Corsair mechanical keyboard, budget around £100 or so. It's replacing a G Pro so something of that ilk, any recommendations please?
I take it you want pre-built mechanical.
Keychron K8 TLK, but avoid the blue switches, unless you like them. It can do wired or wireless. Get the Hotswap version so you can at least swap them out if you don't like it.
But if you go for wired only, and don't mind a more compact keyboard, 75% layout, still have arrow keys, I like the Q1 (metal) or the V1 (plastic).
I recently bought the Q1 v2, it's the best keyboard i've ever had. Keychron also is Mac compatible as well, comes with windows key too if you want to switch to windows.
Both the K8 and V1 is within budget. Q1 is double your budget but it's solid metal.
