corsair link isnt detected when i updated from 1.05 to 1.07
11 Apr 2013
Hi all
today I updated my cordair link from 1.05 to 1.07 and for some reason when I load up the software it will not detect my h80i
so I don't have any options to change fan speed, led etc
althought when I go into the options and devices bit it is listed their saying 1.07
can anybody help please.
With it running and link open, pull the USB cable out and plug back in, it hopefully will pop a box up saying new device detected or similar and ask to reboot.
Hopefully it will then work.
thank you everyone
I followed the uninstall process which wa son that forum Anthony 556 toldme about and it worked so thank you
but anyway I clicked on to check for updates in the software and its coming up that some of my hardware may need updating form 1.07 >>>>> v1.07
