Hi Guys
Starting today, we have a promotion for a few weeks where all customers buying High Performance Corsair Liquid cooling system and an Intel 'K Series' CPU are able to buy their Processor and Cooler together and net a nice saving.
Paired with out two most popular Corsair cooling solutions, the formidable Ivybridge CPUs are kept under control and overclocking potential is increased.
Corsair & Intel Hydro Cooler Bundle - Corsair H80 + Intel i5 3570K OEM @ £253.98 inc VAT
Chosen for ultimate cooling performance with an attractive bundle discount, the Corsair Hydro Cooler Bundle offers great value with superior performance.
Only at Overclockers UK!
Corsair Hydro H80 High Performance Liquid CPU Cooler
Corsair Hydro Series liquid CPU coolers provide a compact, easy-to-install, and maintenance free alternative to bulky, noisy air coolers, efficiently cooling and protecting your high-performance Intel® or AMD® CPU. The H80 features a double-thick radiator to maximize the surface area available for heat dissipation and dual performance matched fans.
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM
Intel's new IvyBridge based CPU's is a refresh that requires socket LGA1155 mainboards based on Intel Z77 Chipset. This new platform uses less power and has vastly superior integrated graphics. The HD2500 graphics is capable of all multimedia task featuring DirectX 11 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD4000 onboard graphics which feature multiple times the horsepower of the previous generation HD2000 making them ideal for gamers and have support for 3D Gaming. The new IvyBridge K series processors also feature immense overclocking as well.
- Lithography Process: 22 nm
- Cores: 4
- Threads: 4
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated HD 4000 Graphics
- Integrated Graphics Frequency: 650MHz (1150MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 1333/1600/1600+ MHz
- TDP: 77W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
By buying this bundle you save £5.00 (6.00 inc vat)
Only £253.98 inc VAT.
ORDER NOW
Corsair & Intel Hydro Cooler Bundle - Corsair H100 + Intel i7 3770K OEM @ £336.37 inc VAT
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler
Featuring a full 240mm radiator and two performance matched 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding performance enthusiast.
The H100 fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Cache: 8 MB shared L3
- TDP: 77W
- Socket: LGA1155
- 1yr Warranty
By buying this bundle you save £8.00 (9.60 inc vat)
Only £336.37 inc VAT.
ORDER NOW
- Cores: 4
- Threads: 4
- TDP: 77W
- Socket: LGA1155
- 1yr Warranty
ORDER NOW
- Cores: 4
- Threads: 8
- TDP: 77W
- Socket: LGA1155
- 1yr Warranty
ORDER NOW
