Corsair m60 tracking problem
23 Mar 2011
Corsair m60 tracking problem- problem solved, update
Hi
I'm having a bit of problem with this mouse, everytime I switch off and on my pc I need to go back in to corsair software to change the lift high, normally would sit at middle then change one up or down then back to normal and everything works fine again.
Anyone had this problem?
Thanks
I'm using on steelseries mouse mat, but it don't make any difference if I use on any other surface, I did use for a while on my desk with out mat and was better but for some reason that don't work any better now, looking on net it looks like I can't upgrade of flush the firmware using windows 10, it happen over night just stopped tracking, but like I posted in my first post this get solved with opening corsair software and just lift high for 1 sec then going back to normal setting.
Don't think I can do anything else, all bios version are up to date ect.
I can't believe it my self, last time I posted was back in June, and I just put up with it every time I powered my pc I had to go in to settings and change the lift high for mouse to work, after multi firmware flushes ect. I just give up and use it and got to the stage where I just didn't switch the pc off, for some reason pc restarted last night most likely due to windows update, anyway I noticed I didn't need to change lift high for the mouse to work :confused:, so I decided to restart my PC, and it works, so 4 months of problem and it suddenly is fixed, what happen??? :confused::confused::confused:
