- 30 Nov 2003
Hi there, I'm currently in the process of building my new computer, but I can't decide which memory to buy.
There is a number of 2GB DDR2 Corsair kits at the place I'm buying from, and I've narrowed it down to two of them, but I can't work out which is better.
2GB (2x1GB) Corsair TwinX XMS2 DHX, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5
Or
2GB (2x1GB) Corsair TwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 4-4-4-12
Other than the difference in CAS latency, which is better? The DHX version is slightly cheaper and uses a bulkier heatsink, but it's CAS is slower for some reason?
I'm going to be overclocking with a C2D E6750, and I've got everything else just waiting on the memory...
Any help is much appreciated! ^_^
Or
