Corsair memory ran into death need advice on which memory to go for
12 Feb 2024
UK
Hey all!
Running a ROG CROSSHAIR X670E HERO with AMD Ryzen 9 7950X and Sapphire Radeon RX 7900 XTX Nitro+ Vapor-X i did have a CORSAIR DOMINATOR PLATINUM RGB DDR5 RAM 64GB (CMT64GX5M2B5200C40) but after several crash to desktop during games i ran a windows memory diagnostic where in i discovered a Hardware issue. So need new RAM. any suggestions?? wanting to game in 4k so would like 64GB and a good clock speed but open to suggestions
You dont need 64gb for gaming, but if you still want it, I would recommend gskill 6000 c30 kit or 6400 c32 if you are able to find it.
Hey all!
i've got a very similar setup to you, 7950x, hero and a 7900xtx mba, but using a 32gb ddr5 dominator platinum 6000mhz kit, on bios 1709 and its rock solid, for games 32gb is more than enough, if you go higher you need to use slower ram due to the capacity, 64gb or more you ned to look at 5600mhz kits or lower, if you stick to 32gb kist then 6000-6200mhz should be achievable.
it all depands if you have a strong cpu with a good memory controller.
Hey all!
Try use TestMem 5 using the ANTA 777 extreme profile instead of the windows test and see if that still returns errors.
