Corsair Mesh
15 Feb 2008
Hi,
Does anyone know the name of the mesh used in the front filter on a corsair 650d case?
Have already bought several different fine mesh but the wholes are larger than corsairs.
thanks
Are you after it to replace yours? If so have you looked on the Corsair store or just asked corsair if they can send you one?
have checked the corair store but nothing found. Just to be clear I'm not talking about the metal mesh that is on the exterior, I'm talking about the mesh used as a fan filter.
I want to use the fine mesh on other parts of my case. Have tried insect screen which the holes are too big to be used as a filter.
