- 3 May 2016
- Newcastle UK
If I had two of the new Corsair ML140's cooling the front rad in my case would I need to have each fan separately connected to its own mobo header to ensure they operated correctly and avoided this known clicking issue when not PWM controlled, or could I use a PWM fan hub and connect both fans to one header?
I have one of the mini modmytoys 4-pin PWM to 4x4-pin PWM circuit boards lying around but want to make sure that the two ML140 will both receive correct signals from the mobo and levitate/perform correctly etc?
Mobo is an Asus Sabertooth z170 mk1 which does have 6 PWM headers but I'm trying to avoid too many extra cables inside the case if possible.
