Corsair Nautilus 500 WC
Not too common around here. Basically made with the design help of Swiftech. Had reasonable reviews but it would have to be very cheap to tempt me as I hate these kind of external all-in-ones.
Its better than many other single-rad kits... block is an apogee. Only downfall is the alu rad.
The swifty single-rad cpu-only kit will still pwn the socks off it though.
Well it costs $175 CDN so I may have to get myself one as that is not too much at all around £99 with the tax. Plus if it can cool better than my current setup in my Sonata II then its worth having.
also interested in one of these.
not too sure how the performance is like though.
my setup is pretty hot with everything running as stock.
x2 4400+ @ 40 idle and 52 load
x1900xtx @ 50 idle and 101 load
i have a lian li v1000+ case.
im not too sure if the single rad will cool this down significantly enough.
i like the fact that its all in one and easy to set up though.
has anyone got any b4 and after temps?
it isnt overclocked. i dont think it is meant to run that hot. but mine does, i tried to change the hsf to zalman v900 but its still that hot.
therefore i need watercooling.
its funny cos i dont think my room is that hot.
I think you need to check if you're having enough cool air entering - I've a feeling your Case temperature is too high - + a Zalman900, it'll not benefit, coz it's only circulating hot air.
its a lian li v1000+ with a air intake at the front and exhaust at the back. both came with the case. thats it not including my psu fan.
i need more fans?
