Corsair Nautilus RS, does anyone have any opinion on it?
13 Apr 2017
Does anyone know this new Corsair AIO? It's been getting some praise for its low noise pump, but I can't quite find any reputable reviews on it.
I was between the LF3 420 and then this popped up. They don't have a 420 model of this, so it would be 360. But on that note I am just wondering if it would be significant less noisy than a LF3 on a good pump curve.
LF3 gets a lot of praise but as I never heard one in action and all I can go with is impressions, I am a bit concerned that it will be too noisy for me even though it allows a lot of customisation with the pump speed and all that.
Obviously the Nautilus RS is much newer ( Oct '24?) and I can just not find that sort of user experience with it. And the only reviews on youtube are AI trash. Any thoughts?
Not much in the way of reviews, but having looked at this and the new Corsair iCUE LINK TITAN 360 RX RGB they are very similar apart from the Nautilus RS does not have ICUE or any RGB, pump seems to be the same but dont quote me on that.
