- 12 Jul 2012
Ive just done a new build using a Corsair Obsidian 650D, its actually my first build.
One question i have, the front fan seems to be quite loud, is that the norm with the stock front fan on this case ? Any suggestions to possibly change it, can the fan speed be reduced at all, my fans are connected to the motherboard, the front fan is on syst fan 2.
One other quick thing, is there supposed to be a fan controller on the case, ive seen all the cabled for it but can't find any dial or switch anywhere or are the cables just there to allow you to add a fan controller ?
