** Corsair Obsidian Deals **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
For the next two weeks we are offering some discounts on our most popular Corsair Obsidian models. It is rare that these models ever get discount as margins are tight but it is certainly worth checking out.
We have included the ever popular windowed 350D which many people have been waiting for discounts on recently too.
Corsair Obsidian 650D Gaming Windowed Midi Tower Case - Black @ £129.95 inc VAT
The Obsidian Series 650D mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.
A large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. The air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. The top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you’re interested in watercooling. And all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.
- Motherboard Support: ATX / mATX
- Expansion Slots: 8
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans
- Front I/O Ports: USB2.0 x 2 / USB3.0 x 2 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller
- Dual 200mm fans provide outstanding cooling for even the hottest components
- Easily accessible dust filters make maintenance simple and hassle-free
- Quick-release side panels make it easier than ever to upgrade your hardware
- Integrated fan controller lets you quickly adjust cooling performance and noise levels
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion
- CPU backplate cutout makes it easy to upgrade your CPU cooler
- Brilliant cable routing system provides a way to keep your system neat and tidy
- Adjustable drive cages can be removed and relocated to accommodate large video cards
- Room for long power supplies gives you peace of mind for future upgrades
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)
Was £135.99 Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
Corsair Obsidian 550D Quiet Midi Tower Case - Black @ £109.99 inc VAT
The Obsidian Series™ 550D has been carefully engineered for noise reduction. The front and side panels are insulated with sound dampening material, and the hard drive trays and fans have soft silicon mounts to absorb vibration. The top and side panel vents are covered for noise reduction if you’re not using them to install your own fans, and even the intakes are angled to reduce air noise.
The rigid, stamped steel and brushed aluminum case holds some remarkable technology that makes it easy to build great systems. There’s built-in USB 3.0 support, and the drive trays work with 2.5” SSDs. The removable hard drive bays allow customization for extra-long graphics cards and maximizing airflow. And, the easy-access side panels come off at the touch of a button for easy upgrades or simply admiring your work.
- Insulated, sound dampening side and front panels
- Six tool-free hard drive trays with integral SSD support and soft silicon sound dampening
- Angled air intakes for reduced noise
- Covered vents for noise reduction if additional fans (not included) are not installed
- Front panel USB 3.0 connectors and audio connectors
- Cable routing cutouts with rubber grommets
- Removable, reversible front panel
- One-button side panel removal for quick access
- Matte black interior
- Three 120mm fans
- Top panel is compatible with 240mm radiators for dual-radiator Hydro Series. CPU coolers and liquid cooling systems
- Eight expansion slots for multi-GPU compatibility
Was £116.99 Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Corsair Obsidian 350D Windowed Micro ATX Case - Black @ £82.99 inc VAT
The Obsidian Series 350D Micro ATX PC case is designed for building compact high-performance systems with Micro ATX and Mini ITX motherboards. The compact size is ideal if space is limited, but there’s plenty of room inside for liquid CPU cooling, dual hard drives, dual SSDs, SLI/Cross Fire ready.
Like all Obsidian cases, the 350D is designed for fast and neat builds, with tool-free access and drive installation. Smart features like a native 2.5” SSD cage make the most of its small size, and the cooling-focused interior has five fan mounting points, with room for two 240mm radiators.
- Windowed Side Panel
- Micro ATX and Mini ITX motherboard compatible
- Brushed Aluminum Front Panel
- SLI / Cross Fire ready
- Five Expansion Slots
- Two 2.5", two 3.5", and two 5.25" tool free drive bays.
- Modular 2.5" SSD cage
- Front 140mm and rear 120mm cooling fans. Room for up to five fans total.
- Direct Airflow Path from front cooling fan to GPUs.
- Maximum ATX PSU length 180mm
- Maximum GPU length 380mm
- Maximum CPU Cooler Height 160mm
- Room for two 240mm radiators (top, front)
- Dual USB 3.0 ports
- Dimensions: 450mm x 210mm x 440mm
- 2 Year Warranty
Was £86.99 Inc. VAT
Only £82.99 inc VAT.
ORDER NOW
Oh my, fancy getting into a corsair case. since they seem to be taking over my computer, hehe.
the 550d takes my eye, nice deals.
