Corsair Obsidian Series 250D Build Spec
5 Mar 2012
South Shields
Hey guys
Im looking to build a second pc for the wife/mates use for gaming nights.
im looking for a spec using this case, i have a 7970 matrix in the cupboard i can use, but not sure if it will fit with it being a 3 slot card!
aby help appreciated!
Not sure but I'd have thought you should be more concerned with the length rater than the number of slots it takes, well unless you're planning on using a sound card etc.
