Corsair or Geil Value kit?
16 Nov 2005
West Midlands, UK.
I'm considering buying a 2GB dual channel kit, but I don't really want to spend too much to be honest.
So which kit would be better, the Corsair Value select of the Geil value; bearing in mind I would like to run them at 224MHz?
Cheers, dagwoood.
vodkacokebloke said:
I cant comment on the corsair stuff, but the Geil 2gb kit im running has been flawless so far, overclocks well too if you ask it nicely
Thanks for taking the time/effort to post vodkacokebloke, it's appreciated.
I assume when you said "..ask it nicely" you've loosened the timings/upped the voltage to get a stable overclock?
sounds silly but i wouldnt expect anything special. id just go for the best timings. Then at least u have the option of dropping a few bits to get to your target
