Corsair PC6400
20 Oct 2005
London
I've purchased one stick of CM2X2048-6400C5 - 2gb to use in a Gigabyte G41M-ES2H am I right in thinking one stick will be fine? Or will this MB only function with both slots populated?
Thanks.
Thanks.
Yes,it'll work ok but it'll be single channel.For dual channel you'll need 2 sticks,preferably a matched kit.If you aren't overclocking then you'll probably be o.k to just chuck another stick of the same memory in to get the dual channel operation.
