Corsair Peripheral Deals! ** Keyboard, Mouse and Headsets **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys!
We have some awesome deals on the new Corsair peripherals.
Corsair Vengeance K60 Mechanical Gaming Keyboard @ £79.99 inc VAT
Cherry® MX Red key switches are the best of the best — they provide the sensitivity and low operating force that professional gamers love. Reaction times are ulra-fast and responsive for quicker double and triple taps. The action is predictable and linear unlike lesser gaming keyboards that have a tactile bump or the annoying click of a typist’s keyboard.
The Vengeance K60 is designed to give you complete control even during the most intense action. The contoured, textured WASD and #1-6 keys are soft to the touch and without slip so you can focus on the game without needing to look down to find the right controls. An extra set of standard typing keycaps and a keycap replacement tool are provided for general typing.
Our expertly designed anti-ghosting technology provides flawless control even when you're pressing multiple keys at once. The K60 has individual switches with dedicated diodes for each switch so every key press results in an input and is 100% ghost free without tradeoff or compromise.
Typical USB gaming keyboards are limited to the USB standard six-key rollover. The K60 features increased performance with a 20-key rollover implementation on USB at a blazing fast 1ms (1000 reports per second) reporting rate.
The comfortable yet rugged design is ideal for single player or LAN party gaming and provides increased durability and stability when compared those that are primarily plastic. The stiff suspension chassis and the laser etched keys are made for durability so they won’t degrade over time.
- Light, responsive Cherry MX Red mechanical switches for fast, efficient gaming action
- 45g actuation Force
- 2mm to actuation and 4mm to bottom
- Rated for 50 million operations
- Gold contacts
- Ten (10) additional sculpted FPS keys (W, A, S, D and 1 to 6) for superior reaction and control — interchangeable with the standard keyboard keys Gaming palm rest with soft-touch surface for superior gaming comfort
- Storage for ten (10) sculpted FPS keys
- Key extraction tool included and storable in palm rest
- Six multimedia keys — Stop, Previous, Play/Pause, Next, Mute, Volume Up/Down — with Solid metal, weighted volume "drum roller"
- Windows Lock key for uninterrupted game play
- Metal top plate for increased strength, durability and rigidity
- USB pass-through connector giving easy access to a USB port on the back of the keyboard (USB 2.0/1.1/1.0)
- USB Connector with gold plated contacts
- Selectable report rate: 1000Hz/500Hz/250Hz/125Hz (1ms/2ms/4ms/8ms) response time
- 2m non-tangle cable
Was £93.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Corsair Vengeance M90 5700dpi Laser Gaming Mouse @ £49.99 inc VAT
You get maximum precision and response from the Avago ADNS-9500 LaserStream™ gaming sensor, even on high resolution displays. Outpace and dominate opposing players with less accurate or slower gaming mice.
The 15 fully programmable buttons are arranged and tuned for intuitive operation without compromising your grip. You get almost effortless access to your frequently-used abilities, macros, button combinations, and spells. Keep your focus on the game, and not the buttons.
The strong aluminum frame is the secret to low weight, high rigidity, and optimal mass distribution. The texturized, soft-touch surfaces are designed for comfort even after extended hours of gameplay. In short... it's designed to simply feel right.
Create up to 50 profiles and share, import and export macros with the Vengeance gaming mouse software. It's a free download at corsair.com.
Play multiple games, with multiple character types? Store up to 6 profiles in memory on the Vengeance M90 laser gaming mouse, so you can easily save your character profiles, favorite macros and frequently used keys. Enjoy the convenience of always having your profiles and preferences even if you switch PCs.
Instantly adjust DPI for precise control when quick changes are needed between different sensitivity settings... all with the simple touch of a button.
When the action is fast and furious, you are constantly moving and repositioning your mouse. The M90 includes lift detection provides high precision tracking and reliable cursor placement even when lifted off of the mousing surface.
The solid metal, rubberized scroll wheel doesn't just feel great — it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
- 5700 DPI Avago ADNS-9500 LaserStream Gaming Sensor
- Adjustable DPI in 100 DPI increments
- 1000Hz/500Hz/250Hz/125Hz — 1msec/2msec/4msec/8msec response time — user selectable
- Tracking rate of up to 165 inches per second, up to 30g acceleration, automatic frame rate control
- Adjustable lift distance
- Five selectable levels to fit your play style
- Surface quality detection
- 15 programmable buttons
- Nine ergonomically placed, side-mounted programmable buttons
- Comfortable ergonomic design with soft-touch surfaces and grip improving textures
- Omron left and right click switches rated for eight million operations
- 48KB of on-board memory for storing up to six "on the go" profiles with active profile LED
- Aluminum metal frame and base for improved rigidity and mass distribution
- Solid metal, weighted scroll wheel with rubberized scroll surface for improved finger traction control and feel
- Ultra Low Friction PTFE pads for smooth performance and accurate gliding
- 1.8m lightweight non-tangle cable
Was £59.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Corsair Vengeance 1500 Dolby 7.1 Professional Gaming Headset @ £64.99 inc VAT
If you have onboard sound, the Vengeance 1500 provides easy one-cable USB connection and Dolby Headphone technology that lets you enjoy multi-channel games the way they were meant to be played. Dolby Headphone is compatible with any game with 3D audio, and helps reduce “headphone fatigue” while delivering the accurate 360-degree audio imaging you need if you’re playing to win.
The massive 50mm drivers greatly reduce the overloading and distortion that can occur with gaming headsets that use 40mm drivers. You get more accurate sound reproduction (particularly for the all-important low-frequency effects). You hear more audio, more cleanly, and you get a competitive advantage.
The extra-wide, extra deep earcups don’t just help things sound great — they feel better, too. Customize your comfort with your choice of the included microfiber or synthetic leather covers. Both use memory foam earpads for a comfortable, reliable fit that conforms to the shape of your head without binding or pinching.
The circumaural, closed-back design blocks distracting sounds and keeps your head in the game, and the extra-large inline volume and microphone control is easy to grab and use when the action heats up — you don't need to take your eyes off the screen.
Whether you’re barking instructions to your teammates or chatting with old friends, you deserve to be heard. The unidirectional, noise-cancelling microphone is tuned to capture your voice loudly and clearly, while screening out distracting background noises. And, it flips out of sight when you’re not using it.
Corsair audio: a sound philosophy
You need more than just dramatic audio. You need the comfort that allows you to play or talk for hours without thinking about what’s on your head. You need fidelity that gives you a listening experience that’s not just immersive — it must also be true to the source material. And, of course, you need the detailed positioning and situational awareness that lets you play your best.
- Intense, Immersive Gaming
- Dominate with Dolby 7.1 Sound
- Superior Comfort
- 3m Cable
- Large 50mm Audio drivers
- In Line volume control
- High-sensitivity noise-cancelling microphone with flexible boom
- USB connections
- Two Year Warranty
Was £75.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Corsair Vengeance 1100 Professional Gaming Headset @ £24.98 inc VAT
With a total weight of less than 160 grams, Vengeance 1100 is the next best thing to nothing. The streamlined design rests lightly on the ears for audio that's heard, but not felt. Clever ergonomics help keep the 1100 firmly in place, so your audio gear never interrupts your gaming, chatting, or video sessions.
The 40mm drivers are extraordinarily large for a lightweight headset they deliver audio with fidelity, accuracy and range that lets you really get into the game and hear your friends and opponents with detailed clarity. And since it's not always about gaming and video calling, the carefully tuned audio will do justice to your favorite music and movies, too.
Whether you're barking instructions to your teammates or chatting with old friends, you deserve to be heard. The microphone's tuned to capture your voice loudly and clearly, while screening out distracting background noises. It flexes to fit your face, and flips out of sight when you're not using it.
The dual 3.5mm connectors work with virtually any sound card and any PC with onboard audio. Or, attach the included USB adapter for great-sounding audio with a single connection. It's PC and Mac friendly and great for gaming on the go.
Soft-touch materials and elastomer headband lining
Vengeance 1100 feels good in your hands and good on your head. The advanced elastic polymer design gives you get a fit that's snug and reliable, without the binding or pinching you might experience on lesser headsets.
- Large 40mm Audio drivers
- High-sensitivity noise-cancelling cardioid microphone with flexible boom
- USB and analog connections for universal compatibility
- Two Year Warranty
Was £29.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
Heard a lot of mixed feedback on the m90, a lot of people in my guild scream bad software whilst one guy claims just plug it in and works a charm. Although he is Finnish.... :P
The K90 has had a price decrease on here from when I bought mine from another retailer as OcUK prices were about £30 more. Now it's right in line with other retailers and you can generally get free shipping with Overclockers as a regular forum poster so it's still a pretty good deal.
This price is around for 1 week more guys! Was gunna end it today, but bugger it. Lets extend it!
