Hello, I need to run this query past everyone before I pull the trigger on an order.
Im going to be running the following.
Armoursuite P50R with 120mm fans (antec ones).
Prolimatech Cpu cooler with 2 antec 120mm white led fans in push pull.
i7 920 G0 at around 3.8ghz
OCZ Reaper 4GB (2x2GB) DDR3 PC3-14400C7 1800MHz Dual Channel
(was told dual channel is about same performance as trichannel, this is cheaper with better timings).
Gigabyte UD5 EX motherboard
1x GTX275
1xGTS250
2x SATA2 HDD's
1x SATA2 DVDRW
The gfx cards ARE NOT going to be run in SLI, they are used for folding, the 275 will be run 24/7 folding as my gaming needs are low ill use the 250 for BF2, and then folding when not in use.
All this off a Corsair 520w modular.
is this safe of do I need a higher spec Corsair Modular ? If so which one ?
Thankyou.
1x GTX275
1xGTS250
2x SATA2 HDD's
1x SATA2 DVDRW
Thankyou.
