- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
We have teamed with Corsair to bring you the best pricing on 2 of their popular PSU's. This promo is for the first 50 units of each PSU. So avoid disappointment and don't miss out!
Corsair Enthusiast Series TX 650W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-650TXV2UK) @ £64.99 inc VAT
The Enthusiast Series TX V2 is part of Corsair’s best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TX Series power supplies are ideal for performance enthusiasts who require an affordable, high-wattage, reliable and highly efficient PSU. Corsair TX V2 Series PSUs are compatible with the latest Intel and AMD platforms and NVIDIA and AMD multi-graphics configurations.
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80PLUS Bronze certified, delivering up to 85% energy efficiency at real world load conditions.
- Active Power Factor Correction (PFC) with PF value of 0.99
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- High-quality Japanese capacitors provide uncompromised performance and reliability
- A five year warranty and lifetime access to Corsair¡¦s legendary technical support and customer service
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
Was £69.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Corsair Gamer Series GS 600W '80 Plus' Power Supply (CMPSU-600GUK) @ £58.99 inc VAT
The Corsair Gaming Series GS600 power supply is the ideal price-performance solution for building or upgrading a Gaming PC. A single +12V rail provides up to 48A of reliable, continuous power for multi-core gaming PCs with multiple graphics cards. The ultra-quiet, dual ball-bearing fan automatically adjusts its speed according to temperature, so it will never intrude on your music and games. Blue LEDs bathe the transparent fan blades in a cool glow. Not feeling blue? You can turn off the lighting with the press of a button.
- It supports the latest ATX12V v2.3 standard and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80Plus certified to deliver 80% efficiency or higher at normal load conditions (20% to 100% load)
- 0.99 Active Power Factor Correction provides clean and reliable power
- Universal AC input from 90~264V — no more hassle of flipping that tiny red switch to select the voltage input!
- Extra long fully-sleeved cables support full tower chassis
- A three year warranty and lifetime access to Corsair’s legendary technical support and customer service
- Over Current/Voltage/Power Protection, Under Voltage Protection and Short Circuit Protection provide complete component safety
- Dimensions: 150mm(W) x 86mm(H) x 160mm(L)
- MTBF: 100,000 hours
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
Was £63.99 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Was £69.99 Inc. VAT
ORDER NOW
Was £63.99 Inc. VAT
ORDER NOW
