Corsair PSU Labels
13 Dec 2002
Newcastle upon Tyne
Not sure if anyone else has had this problem before but my labels are peeling of my Corsair HX650 psu just wondered if they would think this was due to me tinkering and therefore not honour any warranty claims if they ever arrose...
Not sure if its just heat inside the case i used in the past caused the problems but they dont half make it look messy. The label in question is the one with the output specs on it although the blue 650hx one has now started to come off too
Fire off an email to Corsair about it and see what they say. Quite often they'll send you a replacement if you want.
yeah id thought about that, if they could send me just the label that would be great as id hate to have to send the psu off as I believe they have to go to the Netherlands?
I doubt they'd ask you to send the PSU back, postage cost to Corsair is enormous and it'd be a waste for the sake of a sticker.
All you can do is ask them and see what they say. If it's as common as this thread already suggests, they'll probably help you out. They may do anyway.
I've had about 4 or 5 Corsair PSUs and never had this issue, some as old as 4 years now.
Yeh give them a shout on their support forum, they don't seem to have issue with sending people extra modular cables, so certainly worth an ask.
