OcUK Staff
- 26 Nov 2014
- Stoke
Corsair have launched a new PSU promotion today, with some savings across the RM range, along with a decent price cut on the VS550: -
Corsair RM Series RM 650 '80+ Gold' 650W Power Supply (CP-9020054-UK) @ £79.99 inc VAT
Corsair RM Series power supplies are fully modular and optimized for silence and high efficiency. Zero RPM Fan Mode means that the fan doesn’t even spin until the power supply is under heavy load, and the fan is custom-designed for low noise operation even at high loads. 80 PLUS Gold rated efficiency saves you money on your power bill, and the flat black cables are fully modular, so you can enjoy fast, neat builds. And, like all Corsair power supplies, RM Series is built with high-quality components and is guaranteed to deliver clean, stable, continuous power. Connect it to your Corsair Link system and you can even monitor fan speed and +12V current directly from your desktop (additional cable required for 450W-850W units).
Product features:
- Optimized for Silence: The components used to manufacture the RM Series are manufactured specifically for excellent performance and low audible noise.
- 80 PLUS Gold-certified Efficiency: Highly efficient RM Series power supplies produce less heat and have lower operating costs.
- Flat black, Low-Profile Modular Cables: You can use only the cables you need, and leave the rest in the box for fast, easy, and great-looking builds.
- Reliable, Continuous Power Delivery: Corsair uses high-quality internal components, and RM Series power supplies are guaranteed to deliver clean, stable, continuous power.
- Corsair Link Compatible: RM Series power supplies connect to Corsair Link software for real-time monitoring of fan speed and power delivery directly from your desktop. Additional hardware required for 450W-850W units.
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation Intel® Core™ processor Ready (Intel Haswell and Z78 motherboards)
- 80PLUS Gold certified, delivering over 92% energy efficiency at real world load conditions.
- The completely modular cable system allows you to use only the cables you need.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis.
- High-quality capacitors provide uncompromised performance and reliability.
- A five year warranty and lifetime access to Corsair’s legendary technical support and customer service.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- 135MM NR135L Noise reducing fan. MTBF: 100,000 Hours
- Universal AC input from 100~240V.
- Multi-GPU Ready
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, C TUV US, RCM, TUV, CB, CCC, BSMI, GOST, ROHS, WEEE, ROHS, KC
Was £94.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Corsair RM Series RM 750 '80+ Gold' 750W Power Supply (CP-9020055-UK) @ £89.99 inc VAT
Product features:
- Multi-GPU Ready
Was £104.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Corsair RM Series RM 850 '80+ Gold' 850W Power Supply (CP-9020056-UK) @ £99.95 inc VAT
Product features:
- Multi-GPU Ready
Was £119.99 Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Corsair RM Series RM 1000 '80+ Gold' 1000W Power Supply (CP-9020062-UK) @ £124.99 inc VAT
Product features:
- Multi-GPU Ready
Was £149.99 Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
Corsair VS 550W '80 Plus' Power Supply (CP-9020097-UK) @ £35.99 inc VAT
The Corsair VS550 is a great choice if you’re building a home or office system with lower power demands, but you still demand the compatibility and reliability that Corsair is known for.
The VS550 delivers a guaranteed 550 Watts of continuous power. With 0.99 Active Power Factor Correction, you get the peace of mind from knowing that your components are protected from uneven power delivery. And, a dedicated single +12V rail saves you from the hassle of balancing your components across multiple power cables.
The 120mm fan is thermally controlled, so it only spins at maximum speed when it’s pushed hard – and even at full load, it’s pretty quiet. Smart design features like this are why VS550 offers up to 85% efficiency. Your PC system will generate less heat, and you’ll enjoy lower energy bills.
The black powder-coated enclosure and the black-sleeved cables give any system a polished look. You’re building a PC, not a battleship, and with the VS550 you can avoid that look of unpainted steel that you’ll find on so many entry-level power supplies.
VS550 is backed with a three-year warranty, and you get lifetime access to Corsair’s legendary technical support and customer service.
Features
- At least 85% efficient (80 PLUS White 230v EU Certified)
- Corsair engineering and quality control
- 120mm fan
- Plentiful connectors and long cables
- Black housing and all-black sleeved cables and connectors
- 3-Year Warranty
Specifications
- Warranty: Three years
- Model: CP-9020050-NA
- Weight: 3.62
- MTBF: 100,000 hours
- 80 Plus: White
- Power: 550 Watts
- Fanless mode: No
- Fan bearing technology: Sleeve
- Fan size (mm): 120mm
- C-Link Digital: No
- Continuous output rated temperature (°C): 30°C
- ATX Connector: 150mm x 86mm x 140mm
- Modular: No
- Sleeved cables: Sleeved
- ATX Connector: 1
- EPS Connector: 1
- Floppy Connector: 2
- Four Pin Peripheral Connector: 4
- PCIE Connector: 2
- SATA Connector: 4
Was £41.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
These are limited time offers, so if you're tempted, buy soon
Product features:
- Multi-GPU Ready
Was £94.99 Inc. VAT
ORDER NOW
Product features:
- Multi-GPU Ready
ORDER NOW
Product features:
- Multi-GPU Ready
ORDER NOW
Product features:
- Multi-GPU Ready
ORDER NOW
Features
- 120mm fan
- 3-Year Warranty
Specifications
- Weight: 3.62
- 80 Plus: White
- Power: 550 Watts
- Fanless mode: No
- Modular: No
- ATX Connector: 1
- EPS Connector: 1
- PCIE Connector: 2
- SATA Connector: 4
Was £41.99 Inc. VAT
ORDER NOW
