Corsair RAM settings?
25 Oct 2002
I am having a stability issue with my pc. (Often freezes just before 'verifying dmi pool data'). Cpu is @2.77, Ram is at 3-3-3-8 and completely orthos stable.
Can anyone please tell me what RAM voltage should be applied to XMS3200PT 2X1GB sticks and also whether the timings which are stock timings can be changed to solve this issue?
Thanks
m
Thanks
m
Hi Marmoset,
I've got a similar pair (Except 2x512mb and it's C2PT) and i've got 2-3-3-5-1T @ 234Mhz. I use 2.84V though and it's stable. Just make sure you have good airflow over them. Try 2.84V and let us know how it goes.
Thanks for the replies.
PC is in bits at the moment as i've got a new case. Will up the voltage and let you know how i get on.
m
DJKahuna said:
Hi Marmoset,
Me too, was wondering what the optimum settings were for 4x512Mb Cas2's?
