Corsair Release New Range of Fans
15 Feb 2006
Staffordshire
http://www.corsair.com/cpu-cooling-kits/air-series-air-cooling-cpu-cooler.html
Corsair Adds Cooling Fans to Product Line
“ New Corsair Air Series Fans Target Critical PC Hot Spots, with Superior Airflow, Lower-noise, and Customizable Looks“
Fremont, California — May 3, 2012 — Corsair®, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced the new Air Series™ line of PC cooling fans. Unlike most other PC fans in the market, Corsair Air Series fans are offered in airflow and static pressure models, each specifically optimized for specific PC cooling roles.
Air Series fans are designed to deliver an extraordinary balance of airflow and low-noise to users who want to upgrade their PCs for quieter operation or higher performance. All feature an advanced hydraulic bearing system and rubber mounts for low-noise and reliability, and include red, white, and blue color rings to allow users to customize the look of their PC.
High Airflow Fans for Efficient Large-Volume Cooling
Air Series AF120 and AF140 airflow fans are designed to intake cool air into, and exhaust hot air out of, modern PCs. They are for ideal for mounting on the side, top, and rear of cases, to reduce component-killing heat. The airflow fans are designed with ultra-thin, custom-molded blades optimized to flow high volumes of air in unrestricted spaces with at least 3cm of clearance. They are available in a 140mm Quiet edition and in 120mm Quiet and Performance editions.
Edition Description Size
(mm) Noise (dBA) Airflow
(CFM) RPM
AF120 Quiet Low noise,
Good airflow 120x25 21 39.88 1100
AF120 Performance High airflow 120x25 30 63.47 1650
AF140 Quiet Low noise,
High airflow 140x25 24 67.8 1150
High Static Pressure Fans for Efficient Cooling on Radiators or Heatsinks
Air Series SP120 fans deliver focused air pressure in situations where air needs to be blown through a restricted space making them ideal for cooling radiators and heatsinks. They feature seven ultra-wide, custom-molded blades and a custom enclosure that delivers high static pressure, while maintaining a quiet noise profile. Available in a 120mm size, SP120 fans are available in Quiet and High Performance editions.
(mm) Noise
(dBA) Airflow
(CFM) RPM Static Pressure
(mmH2O)
SP120 Quiet Low noise,
High pressure 120x25 23 37.85 1450 1.29
SP120 High Performance High pressure 120x25 35 62.74 2350 3.1
"Many PC fans on the market are general purpose designs that not always suited to the task which they’re assigned," said Ruben Mookerjee, VP and General Manager of the Components Business Unit at Corsair. "We took our expertise in PC case and cooling and designed fans that have very specific uses. Each fan is the right tool for the right job.â€
Pricing and Availability
Air Series fans are immediately available starting at a suggested retail price of $16.99 USD for AF120/SP120 fans and $18.99 USD for AF140 fans.
For more information on Air Series fans, please visit the cooling section of our web site and our Air Series fan blog post.
www.corsair.com/cooling
www.corsair.com/blog/introducing-corsair-air-series-fans
Images of the new Air Series fans can be downloaded from here:
https://corsair.sharefile.com/d/sc24fa8e0e534fcd9
About Corsair
Founded in 1994, Corsair supplies high performance products purchased primarily by PC gaming enthusiasts who build their own PCs or buy pre-assembled customized systems. The company's award-winning products include DDR3 memory upgrades, USB flash drives, power supply units, solid-state drives, PC speakers, gaming headsets, gaming keyboards, laser gaming mice, system monitoring and control devices, CPU cooling products, and computer cases.
These look really good, a nice change to an other wise boring area, the red would go well with my new board.
Couple of pics
looks like a nice set of fans.
shame i'l happy with the ones i've got and can't justify it lol.
Shame their research didn't conclude how few 140 pwm fans there are and set out to produce one to rival noctua's but that you can actually buy. Then the colours would be the iceing on the cake and they would've pulled off the same win as Phanteks have.
Love the concept. Designed for specific purposes, high flow for intake/exhaust and high pressure for radiators and heatsinks.
Not to mention the rubber isolation and customisation with the colour rings. Winning combo right there.
