Corsair Rep i need some advice please
22 Nov 2010
Kettering
hello,
im having a problem with a AF140 quiet edition fan, i have it mounted as exhaust in the roof of my CM storm trooper and its making a slight knocking noise, i can hear it over my SP120 quiet editons that are at full speed all the time.
its been the same since the day i got the fan, i did not bother doing anything as i hoped it would go away after a bit of use.
When i push on the center of the fan slightly, it goes away, so is it ok to request a RMA? ive never dealt with corsair RMA and im at work atm, btw i no longer have the fan packaging, but i do have the other colored rings and the 7v cable and screws.
have you experienced this before? is it a common problem or is there a fix i can do easily?
thanks
