- 25 Sep 2018
Hello all,
I just have a quick question about my upcoming build. I want to use four ML140MM RGB and three ML120MM RGB fans around my case and I want to make sure I fully understand how everything needs to be connected in order for me to control lighting through iCUE.
If I understand everything correctly I should plug the fan PWM cables into the PWM headers on the Corsair Commander Pro (using one splitter cable to connect 7 fans to 6 PWM hubs) and plug the RGB cables from the fans into two Corsair RGB LED hubs which themselves connect to the two RGB LED headers on the Commander Pro. I believe I can also plug my H150i USB connector and the USB connector from my HX100i into the two USB ports on the Commander Pro.
Both the RGB hubs and the Commander Pro need to be plugged into SATA ports from my Corsair power supply, and the Commander Pro's USB cable can be plugged into an internal USB header.
Is this the correct way to connect everything? Will I be able to control the lighting from all of my fans by connecting everything this way? Would I also be able to control my fan speed?
Thanks!
Thanks!
