Hi folks,
Anyone have any experience with these? Built my new rig last summer, but never had the rear fan RGB working. I have a H100i AIO which comes with the RGB connectors so the rad/fans all worked fine.
Earlier this year got the Commander Pro - useless tbh, didn't realise it had no RGB connections just 2 LED strips and 6 fan headers mainly. Then realised I needed the £10 Corsair RGB Hub so I could use it combined with the CP to have up to 6 fans and 6 RGB headers in use.
Got the RGB hub yesterday, connected it this morning - none of the RGB works now... Could it be a DOA unit or could I be a pleb with my connections? I'm connected via ports 1-3 (2 from AIO and my 1 rear) on the hub. Tried 4-6 none work for any of the fans.
I can't see where I've gone wrong. The CP still works and is recognised... the RGB Hub has SATA power, it has the 3-pin connector from Hub -> CP in LED port (checked 2 youtube vids all do the same) so it can talk to that. The 3 fan headers are in the CP and work fine, but the 3 RGB headers in the hub are doing nothing it seems.
If all sounds correct, can only assume unit is DOA and contact OcUK to sort a replacement. But never expected Corsair's kit to be so bloody complicated and needing multiple hubs for such a simple task...
Any advice be appreciated
Cheers
Cheers
