Corsair RGB not working
Permabanned
30 Dec 2021
Yorkshire
I installed Asrock RGB software... it docent work.
Any its bummed all my RGB. nothing works right.
my keyboard I've sorted (logistic)
my mouse is fixed on white, and my ram is LED's off all the time. My gpu is ok until i open icue the it go's black.
i have uninstalled Asrock RGB software, nothing. i uninstalled and reinstalled iCue and nothing.
if i force a firmware update the LED's work until the update it donn then off
Multiple RGB software for devices are a recipe for disaster, if you think youve got it bad, try ANUS Armoury Crate, makes you computer lovely and laggy, I installed it yesterday and uninstalled it today.
There 2 options:
OpenRGB or Signal RGB, I found signal quitte hard to get used to, but OpenRGB was pretty easy.
Signal: https://www.youtube.com/watch?v=ymUum2FTJMY
Open: https://www.youtube.com/watch?v=C4O9ci5zpm8
Nope I just want Icue to work. I needed one more header so wanted to use the ones on my motherboard.. I’ve not uninstalled all that crap and ordered a splitter but…
My problem is with everything uninstalled nothing works.
With only one problem installed nothing works
And so on…
