Corsair Rm650
10 Apr 2007
UK
I built a new system and it is all running fine but for the last 10 days I have had a smell/fume of a electrical, it is quite overpowering after a while at my desk.
Thought it was the new pc smell but doesn't seem to be disappearing.
It seems to be coming from the psu, it isn't hot to touch and fans are not going crazy and I have had no problems with the system.
I am not using to low of power on this spec am I?
Msi Z97m
16g 2666 ddr3
i7 4790k devils canyon
Asus hyper m.2 x4 m2 card
Samsung sm951 m2
crucial mx200 ssd
lg blu ray writer
msi gtx970 4g gaming
be quite slim rock cooler
2 x 120mm fans + 200mm fan
I doubt if you are pulling 350w at the wall so it's more than powerful enough. Burning smell=not good. You need to find out where it's coming from asap. Take the psu out and inspect it through the fan to see if you can see anything. Personally I wouldn't be using it.
That doesn't sound good. Do you know if its being triggered by something? like is the odor present while your system on idle? or it only start the burning smell when you put your system under load?
Best is to find out where the source is.
