I'm in the process of upgrading most of the internal components of my PC including the motherboard and PSU.
I bought an MSI MPG X570 Gaming Plus motherboard and a Corsair RM750i PSU (and other things).
This motherboard needs a 24 pin ATX_PWR1 and an 8 pin CPU_PWR1 cable, which are supplied.
Additionally, the motherboard needs a 4 pin (2 x 2) CPU_PWR2 cable which is not supplied.
I tried powering up with just the two supplied cables and the fans started spinning but it doesn't boot.
So Corsair only supply two of the three required CPU power cables.
I wanted to check that this PSU is suitable for this motherboard and which additional cable I need to buy. Maybe the Akasa 4 pin to 8 pin ATX PSU adapter (Stock code: CB-063-AK)? But plug it in where, the only unused sockets on the PSU are 6 pin or PCIe?
Would appreciate some suggestions as to the right cable or PSU for the motherboard. Thanks
