Corsair RMi PSU and Corsair Sleeved Cable Kit ?
19 Feb 2007
Area 18, ArcCorp
I got the Corsair RMi 1000w a few days ago and I like the looks of the sleeved cable kit.
Anyone know if they are compatible ?
A comment on the cable kit store page said it's compatible with the previous RM series but I just need to know for sure before I order as the RMi series isn't mentioned on the cables store page.
PSU - https://www.overclockers.co.uk/showproduct.php?prodid=CA-204-CS&groupid=701&catid=123&subcat=1084
Cable Kit - https://www.overclockers.co.uk/showproduct.php?prodid=CA-123-CS
I would go with the Cablemod ones. They don't have any visible heatshrink so they look nicer imo.
YOUR BASKET
1 x CableMod C-Series AXi, HXi & RM Cable Kit - Black £69.95
Total : £75.92 (includes shipping : £4.98 Ex.VAT).
You can see compatibility here which lists the RMi 1000W:
http://cablemod.com/compatibility/
It says on Cablemod website that you need to contact support regarding the 24 pin cable, although the bundle above lists/shows it in the description. It might be an idea to check with OCUK or Cablemod to find out.
