Corsair SF750 AWG size
7 Oct 2015
As title says, whats AWG wire size is used for the Corsair SF720 PSU? (ATX, EPS, SATA basically all)
I'm thinking of making my own cables for this PSU as the cables supplied are too long.
Also if i remember this PSU contains a Sensor cable. Is that really needed?
Taken from Tom's Hardware review of the SF750:-
Cables & Connectors
Modular Cables
Description
Cable Count Connector Count (Total) Gauge In Cable Capacitors
ATX connector 20+4 pin (300mm)
1 1 16-18AWG No
4+4 pin EPS12V (400mm) 2 2 16AWG No
6+2 pin PCIe (400mm+100mm) 2 4 16AWG No
SATA (100mm+120mm+120mm120mm) 2 8 18AWG No
4 pin Molex (100mm+120mm+120mm) 1 3 18AWG No
AC Power Cord (1380mm) - C13 coupler 1 1 16AWG -
cool thanks for this.. and how about the sensor wire? I heard some models require that cable in order to function properly, while others don't... and also depends on whether you are making cable extensions (to which a sensor wire is not required), whereas if you were to make direct cables, you do
Curious, does the EPS/ATX/PCIe cables have to be 16awg? Would there be complications if i used 18awg for these cable sets? and if so, what complications would they be? From what i've heard, they are practically identical, just the 16awg is thicker and harder to bend than the 18. Anything else i need to be cautious of?
Thicker cable can carry more load before becoming hot/melting.
ATX standard was written long before the days of graphics cards that could pull 300w+ though and needed direct feeds from the PSU?
It was first written a long time ago, but it's updated regularly to cope with things like 300W GPUs. The 18AWG recommendation is from Desktop Platform Form Factors Power Supply Design Guide June 2018.
To put some numbers to it, a 300W GPU, assuming it had a 90% efficient VRM and used only 12V, would pull 28A total. Two PCIe cables have a total of 6 12V wires, so less than 5A per wire. That's well within what an 18AWG wire can handle without melting.
I emailed a company (which according to them cables the 8pack systems at OCUK) regarding AWG sizes and what's best recommended for Corsair PSU. They said 18awg is fine and have cabled PSU handling more than 2kw of power. Kinda saves me some money as i had cabled a few using 18awg and just wasn't sure if i had to purchase more silicon wire at 16awg as i thought i bought the incorrect wire
