Corsair SF750 Platinum 3x8 pin question
24 Jan 2015
Hello guys I need your advice Im upgrading to a 7900xtx with 3x8 pin connection my current gpu is a 2x8pin I have two 8pin cables coming from my psu to the gpu currently each of these cables has an extra 8 pin for my new gpu can I connect the third 8pin from that cable or should I plug another 8pin coming directly from the psu?
Another 8 pin coming directly from the PSU.
As your psu only has a pair of dual 6+2 pin pci-e cables you can't really use three seperate cables so one of the connectors being daisy chained off the same cable should be fine. Do not use the spare 8 pin cpu power on a gpu, not that it should fit the socket anyway.
