- 20 Jul 2009
- The bleak North East arm pit of Britain
OcUK have just received our shipment of Corsairs awesome SP2500 2.1 speaker system ready to ship to your door! All pre-orders will be shipped today so get in quick as stock is limited
Corsair Gaming Audio Series SP2500 High-Power 2.1 PC Speaker System - 232 Watts RMS @ £229.00 inc VAT
Since you have only one PC speaker system, you don’t want to make sacrifices. That’s why Corsair has created the SP2500.
At its heart are six Class D amplifiers driven by an ultra-efficient power supply. The 8” subwoofer driver is housed in a fourthorder bypass enclosure for clean, tight bass response that can seriously shake the room. The bi-amplified satellites use specially developed 3” drivers and custom-designed, ferrofluid-cooled 1” silk dome tweeters for detailed audio reproduction across the entire spectrum with great stereo imaging and a generous sweet spot. A programmable digital signal processor lets you craft the audio to your liking. It’s all under your command with the 1.8” (4.6cm) color display desktop controller.
- 232 Watts RMS of continuous power delivery through six Class D amplifiers
- 8” subwoofer with durable rubber surround in a fourth-order bandpass enclosure
- Bi-amplified satellites with 3” drivers and 1” ferrofluid-cooled silk dome tweeters
- Clean, high-fidelity audio reproduction with excellent stereo imaging
- Programmable digital signal processor for advanced dynamic audio processing
- Wired desktop controller with 1.8” (4.6cm) color TFT display and multi-lingual interface
Specification:
- Frequency response of 35Hz – 20kHz +- 3dB
- 232 Watts of total power (measured via FTC “RMS” method)
- Subwoofer: 18.1” x 10.2” x 11.7” (46 x 25.8 x 29.7cm) enclosure with fourth-order bandpass design for accurate bass reproduction
- Subwoofer: 8” subwoofer driver with durable rubber surround
- Subwoofer: Bridged dual 60 Watt class-D amplifiers with integrated DSP for 120W of power (measured via FTC “RMS” method)
- Subwoofer: Ultra-efficient integral power supply with 100V – 240V AC input
- Satellites: Bi-amplified, two-way design with detachable audio cables
- Satellites: 3” midrange drivers
- Satellites: 1” custom-designed, ferrofluid-cooled silk dome tweeters
- Satellites: 4.25” x 4.7” x 6.25” (10.8 x 12 x 15.9cm) enclosures with asymmetrical tweeter placement for superior stereo imaging
- I/O, Controls, and Programming: PC input on subwoofer
- I/O, Controls, and Programming: Dual 3.5mm auxiliary inputs (one on subwoofer, one on desktop controller)
- I/O, Controls, and Programming: 3.5mm headphone out with digital signal processing
- I/O, Controls, and Programming: Wired desktop controller with 1.8” (4.6cm) color display and multi-lingual interface
- I/O, Controls, and Programming: Digital signal processor with active crossover capability
- I/O, Controls, and Programming: Mod X™ theatrical audio processing for Blu-Ray and DVD audio that recreates the theatre experience
- I/O, Controls, and Programming: Dynamic DSP programs and EQ curves for late night listening, environment simulation, and optimal enjoyment of games, movies, and music
- Package Contents: x1 subwoofer, x2 satellites, x1 desktop controller with 6’ (1.8M) cable, 3.5mm to stereo RCA cable for PC input, 6’ (1.8m) satellite cables with ATX connectors, Power cable, User Guide
- Retail box dimensions: 22.75in L x 19.75in W x 15.75in H (57.8cm x 50cm x 40cm)
- Weight: 30.75 lb (13.9 kg)
Only £229.00 inc VAT.
ORDER NOW
Specification:
ORDER NOW
