Corsair Spec-01 Red/Black theme build
The Specs:
- 8GB DDR3 Corsair Vengeance 1600MHz
- MSI 970 Gaming Motherboard
- Corsair CSSD 60GB SSD
- Corsair H60 Hydro CPU Cooler
- AMD FX6300 Black Edition @3.5GHz
- Corsair Carbide Series Spec-01 Case
- ASUS VE278H Widescreen LED Monitor
- Graphics Card *Unconfirmed*
- 2x 500GB Seagate (Storage Drives)
- Corsair CX 600W PSU
First of all this is my first build so go easy on me!
Note: The pictures aren't the greatest so apologies for that
I wanted to build a gaming PC that wouldn't cost too much so I went with good all bang for £ AMD. The FX processors seem to have good benchmarks and are overall very impressive for their value.
So here goes.
Here is the current game room:
My current PC I have had for about 3-4 years and its just being used as an Arch Linux file share at the moment as its pretty old.
So Yesterday all my kit arrived (apart from Graphics Card and SSD :/)
I took my old TV off the wall and have started to begin mounting the bracket for my 27" Asus VE278.
Unfortunately I got distracted half way through so its not up on the wall yet.
So swiftly moving on..
The PC,
So I started with the PSU (annoyingly its green and I wanted a red theme but no biggy just means I'll have to swap it for an AX or AXI series PSU later on)
Fans:
MSI 970 Gaming Motherboard, this has got to be my favourite item I purchased I'm overall very pleased with the colour and quality of this motherboard:
Got a pretty cool door hangar too (don't be fooled this doesn't keep women away, she still enters the room..)
I'm sure most of you will know but don't forget to put your 8pin PSU cable through before installing the motherboard this nearly caught me out!
and here is the rest:
Thanks for looking, I'll hopefully get some finishing photo's up later with some better pictures. Unfortunately I done a lot of the work in quite a dim room so the pictures lack quality and light.
