Corsair TX650
25 Sep 2010
PC occasionally shuts down with Kernel 41 error. Think I might need new PSU. Can someone please recommend replacement for Corsair TX650?
Many thanks in advance for any replies.
Russ
What are the rest of your specs? Most importantly, CPU and graphics card.
Do you plan to upgrade to a new graphics card in the future? If so, what class e.g. xx70, xx80?
Not a lot is in stock at the moment.
If you want something cheap(ish), I guess the pure power 12. It is non-modular, but it has a 10 year warranty and the 12M reviewed fine (review here). I'm not sure if anything else was changed between the two versions, I can't find any confirmation either way.
The Phanteks AMP GH has an 8 year warranty and the platform appears to be the same as this reviewed one. Helly are often used for Seasonic's lower-end PSUs (Phanteks previous model AMP, had Seasonic as the OEM).
The Antec is derived from Seasonic's Vertex and has a 10 year warranty (12 on the Vertex), with good quality parts and is a step above the other two, but obviously that is reflected in the price.
I've checked that these PSUs have a -12v rail, because for older systems this can be needed and has been dropped by some models (like Corsair's new RMx).
They also say that the 8 pin PCIE connectors can split from 8 to 6 (listed as 6+2), which I believe you will need for the GTX 460?
My basket at OcUK:
Total: £322.84 (includes delivery: £7.99)​
